Knobbies on 2.5 x 17 or 3.5 x 17 rims????
Results 1 to 14 of 14
Thread: Knobbies on 2.5 x 17 or 3.5 x 17 rims????
  1. #1
    Join Date
    Aug 2004
    Location
    New York City......
    Posts
    5,434
    Default Knobbies on 2.5 x 17 or 3.5 x 17 rims????
    Can you get knobbies for small 17's? I now some guys put them on 4.25 x 17 I have a TTR with SM wheels on it but do not have the stock wheels. Thanks.
    07 Yamaha WR250F/ 07 KTM 144/ 07 BMW 650 X Chall/ 05 XT225/ 79 XT500
    Help/ Support a legend (Doug Henry) http://www.road2recovery.com
  2.
    Advertisement
  3. #2
    Join Date
    Mar 2005
    Location
    York SC - just below Charlotte
    Posts
    8,613
    Default
    Get some road race rains. I picked mine up 2 laps used!
    Here they are mounted on the YZF wheels I am selling.
    www.MotoHose.com
    Don't bring a gun to a snowball fight!
  4. #3
    Join Date
    Aug 2004
    Location
    New York City......
    Posts
    5,434
    Default
    I want to throw some spikes in them for ice racing. I dont think rains will work. I already have a set of them.
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Aug 2004
    Location
    Kirkland, Washington, United States
    Posts
    2,767
    Default
    You are right, rains don't have enough depth to hold the screws without cutting the tube.
    For screws: order a set of 1000 gold cutters that are 7/16" of an inch. They are in the tucker rocky catalog.
    I put a kenda 4.10x17 on the front 17x2.5". Keep in mind I have a KX80 front end on my bike (which is wider). You might need a narrower tire if you run the stock forks.
    I'm sure there are plenty of 17" knobs to be found in the off brands like kenda or chen shin, since 17" is the front rim size of a most of the 85's (non-expert models).
    Get a hard terrain tire if possible (more knobs, tighter pattern).
  7. #5
    Join Date
    Aug 2004
    Location
    New York City......
    Posts
    5,434
    Default
    Thanks Ron. I will have to do some research. I hope to get the TTR out on the ice sometime this winter.
    Quote Originally Posted by ronwest99
  8. #6
    Join Date
    Aug 2004
    Location
    Snohomish, WA
    Posts
    1,320
  9. #7
    Join Date
    Dec 2005
    Posts
    473
    Default
    i have heard of people putting a stripped down carcass on the inside of the mounted tire to keep the screws from tearing up the tubes.
    this is all just heresay, but, using that rational, i would think that you could use just about any tire you wanted and it would work.
  10. #8
    Join Date
    Aug 2004
    Location
    Posts
    2,767
    Default
    with the right length screws you don't need anything extra inside the tire.
    Slime never hurts for insurance on this though..
  11. #9
    Join Date
    Dec 2004
    Location
    Averill Park, NY
    Posts
    267
    Default
    If the tires do not hook up you will probably be packing up. I feel confident in stating that there is a lot of talent, patience and skill involved when making a great ice tire. Usually people attempt to make their first set of ice tires for several reasons... cost, cost, cost. Many of those same people break down and buy pro-built tires after riding another bike that has had pro-tires installed. Why? because the pro-tires stick to the ice like a SuperMoto bike running fresh scuffed in slicks on a hot summers day. I can not tell you how to build a pro tire, because I do not have the talent, skill or patience it takes to build one. But I can give you some direction on how to get a set of pro-built tires and how to treat them once they make it on to your bike. Go here:
    Canadian Motorcycle Ice Tires
    http://rockcentralcycle.supersites.ca/icetires/
    TIRE WRAPS: Buy or make them, just make sure to cover up anytime the tires are not on the ice.
    The future of winter motorcycle road ice racing:
    http://www.dieseljo.com/images_ice_p...x_ice_bike.jpg
    MFG-Racing.com
    #94 Expert LRRS, CCS, SMUSA
    KTM 525 SMR: FOR SALE HERE!
    Honda XR100 'tard
    Team Speedbike Racing (http://www.Speedbike.com)
  12. #10
    Join Date
    Jul 2005
    Location
    Newberg, Oregon
    Posts
    307
    Default
    Just a thought, but Chen Shin and IRC make trials tires and a couple knobs combos. Maxxis has a 17 front and rear knobby combo also.
  13. #11
    Join Date
    Aug 2004
    Location
    New York City......
    Posts
    5,434
    Default
    Macman do you have any links or pics?
    Thanks
    Quote Originally Posted by MACMAN
  14. #12
    Join Date
    Jul 2005
    Location
    Newberg, Oregon
    Posts
    307
    Default
    I looked here (not an indorsement as I have never done business with them, but use it to look to see what's available)
    TIRES UNLIMITED
    Check out the different brands and you can see where you can come up with some combinations that should work for you. I was actually thinking about seeing what I could put on my 150 motard with the 17's also. Thinking a trials tire might actually be some fun.
  15. #13
    Join Date
    Aug 2004
    Location
    Snohomish, WA
    Posts
    1,320
    Default
    Stay away from the trials tires, I tried it and the blocks are siped and will not hold screws.
    Anyone want to buy a new never used trials tire, only has a few holes in it?
  16. #14
    Join Date
    Jul 2005
    Location
    Newberg, Oregon
    Posts
    307
    Default
    Sorry..guess I wasn't just speaking of placing screws in them. I was thinking of plonking around on the track and trails also.
  17.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
