2004 Husqvarna TE 450 Supermotard Build
Page 1 of 2 12 LastLast
Results 1 to 50 of 53
Thread: 2004 Husqvarna TE 450 Supermotard Build
  1. #1
    Join Date
    Sep 2011
    Posts
    33
    Cool 2004 Husqvarna TE 450 Supermotard Build
    Hey everybody, I'm brand new to the forum thought I'd share my first supermoto build.
    Picked up a husky for five hundred bones so thought I should go all out on the conversion (within sensable reason) Heres a couple early pics. I'll be using excel wheels with talon hubs from motostrano and the ebc brake rotor kit. Somehow I decided I needed $200 worth of Rizoma turn signals when I realized they weren't sold in pairs Close to half the cost of the bike but they're freakin awesome!! lol Now just have to try to figure out the flasher wiring. Found a handlebar switch on motostrano that had everything I needed and a Trail Tech Vapor to go on the tree. Using pressure switch banjo bolts for the brakelight. Going to drop 8 teeth in the rear sprocket and run a 42.
    Question for TE450 Husky owners ...... Will a 5' rim clear the chain with a 160 on the rear? Or should I go for the 4.25?
    More to come once some more parts show up
    By the way, I went ahead and ordered a leather suite as well
  2.
    Advertisement
  3. #2
    Join Date
    Sep 2005
    Location
    Utah
    Posts
    1,875
    Items for Sale
    Default
    Nice score! If you didn't already order the wheels there is a set in the classifieds. The 5" fits easily. Get an exhaust it really helps out. Also I didn't really like the look of my 04 so I bought seat tank plastics from a06 they fit without modification. Good luck. I'm looking for a set of dirt wheels if you want to sell yours let me know.
  4. #3
    Join Date
    Sep 2011
    Posts
    33
    Default
    I saw the classifieds but I'm pretty picky about wheels. I really want to start off with a fresh set. As for my dirt wheels, I need to keep them, its too much fun to let them go. If you can see my exhaust, I performed a conservative bafflectomy shortening operation so I'm hoping I can get by with that for a little while. Do you have any problems with your titanium valves? I am considering doing the stainless conversion with stronger springs this winter to make it more dependable and easier to start.
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Sep 2011
    Posts
    33
    Default
    It took a coil and a new spark plug to get it going in the dirt, and a few nuts and bolts... and a carb rebuild/cleanout
  7. #5
    Join Date
    Sep 2005
    Location
    Utah
    Posts
    1,875
    Items for Sale
    Default
    Valves don't need much attention on the huskies. Check them often because you should and it's easy. You will hardly ever have to shim them. Bike looks great!
  8. #6
    Join Date
    Sep 2011
    Posts
    33
    Default
  9. #7
    Join Date
    Sep 2011
    Posts
    33
    Default
  10. #8
    Join Date
    Sep 2011
    Posts
    33
    Default
  11. #9
    Join Date
    Sep 2011
    Posts
    33
    Default
  12. #10
    Join Date
    Sep 2011
    Posts
    33
    Default
    Thought the pressure switch might melt if I put it on the master....
  13. #11
    Join Date
    Sep 2011
    Posts
    33
    Default
  14. #12
    Join Date
    Sep 2011
    Posts
    33
    Default
  15. #13
    Join Date
    Sep 2011
    Posts
    33
    Default
  16. #14
    Join Date
    Sep 2011
    Posts
    33
    Default
    Already stocked up on rubber from my buddies!
  17. #15
    Join Date
    Mar 2011
    Location
    Erie, PA
    Posts
    673
    Default
    Nice find man! I think its awesome to pick up a cheap beat up bike completely redo it from top to bottom and make it somthing awesome! By the way bike looks freaking awesome nice work Definately looking forward to see how the build progresses!
  18. #16
    Join Date
    Sep 2011
    Posts
    33
    Default
    Thanks, I'm just waiting on one backordered turn signal to get it registered. The wheels should show up next week along with my leathers and it's game on!! I guess I'd better start working on some kind of kickstand soon....
  19. #17
    Join Date
    Oct 2010
    Location
    Croatia
    Posts
    133
    Default
    Im looking forward to see how this build will go , always loved to buy beat up bikes then work on them.
  20. #18
    Join Date
    Sep 2011
    Posts
    33
    Default
    My $8 kickstand attempt... Just have to do something a little different for the spring setup and add a sink plate on the end. I couldn't see spending over $100 on a kickstand!
  21. #19
    Join Date
    Mar 2007
    Posts
    6,362
    Items for Sale
    Default
    Quote Originally Posted by Rexchop View Post
    Wow!! That is beautiful. I love the old blue and yellow. If you haven't ordered wheels already you Shoukd find a used set off a smr, and a set of forks and jyst use the stock brembo radial setup.
    2006 husqvarna 530rr. AKA "dirtyfivethirty" or "freight train " Formerly known as Alohar1
    www.FastBikeIndustries.com www.ksrwheels.comwww.balidogrefuge.com
  22. #20
    Join Date
    Sep 2011
    Posts
    33
    Default
    Finally got some parts! Too bad the husky specific sprocket does not fit the talon hub. What sprocket do I need?
  23. #21
    Join Date
    Sep 2011
    Posts
    33
    Default
    Nevermind on the sprocket deal, they just gave me the wrong one.
  24. #22
    Join Date
    Mar 2007
    Posts
    6,362
    Items for Sale
    Default
    If memory serves I had a hwd issue with my front rotor. Stock hwd wouldn't work. Used some other husky bolts and used loctite. Then one backed out while I was riding. Causing bad shit to go down. After a new rotor I used long bolts all the way threw the hub, nut on back and safety wired. Lol over kill but it was random that mybrotor bolts came loose. The wheels were a week old. Jyst keep an eye on it. I have no idea why husqvarna chooses to only use 4 bolts to hold on something that gets that amount of pressure.
  25. #23
    Join Date
    Sep 2011
    Posts
    33
    Default
    Ouch! I'll use that idea about longer bolts and metal locknuts on the back with threadlock.
  26. #24
    Join Date
    Mar 2007
    Posts
    6,362
    Items for Sale
    Default
    btw i cant wait to see your bike finished!! im a huge fan of the old school huskys!
  27. #25
    Join Date
    Mar 2007
    Posts
    6,362
    Items for Sale
    Default
    btw this is a shot in the dark here... by the looks of your garage your in the military... and by looking at the valve stem caps (yellow ones) im guessing your in aviation. they look exactly like the aircraft tire valve caps
  28. #26
    Join Date
    Sep 2011
    Posts
    33
    Default
    I'm not in the service yet, it's very possible in the future (I'm 23) but I do work in aviation. I got the bike off a buddy at work that had it overseas, where the valve stem caps came from.
  29. #27
    Join Date
    Sep 2011
    Posts
    33
    Default
    Here's some eye candy for ya!!
    Just waiting on rotors and some wide rim bands to mount the tires. Started the title process yesterday.
  30. #28
    Join Date
    Mar 2007
    Posts
    6,362
    Items for Sale
    Default
    Nice job!! Keep up the good work
  31. #29
    Join Date
    Sep 2011
    Posts
    33
    Default
    I finally have the wheels back from the shop with no luck on rotors, maybe they'll figure it out this time and order the right ones. But here's some pics... I just threw on the dirt rotors just so I can tool around a little. Hopefully I will get the title this week in the mail so I can get a tag soon.
  32. #30
    Join Date
    Dec 2010
    Location
    TN
    Posts
    2,447
    Default
    Man those wheels look sweet on there Here's a pic of mine, it was stock when I traded for it.
    I picked up a FBF full exhaust which woke it up a good bit.
  33. #31
    Join Date
    Jul 2009
    Location
    Northern utah
    Posts
    4,682
  34. #32
    Join Date
    Sep 2011
    Posts
    33
    Default
    Yea, 5" with a 150 and 3.5" with a 110 on the front. I have enough clearance to do a 120 in the front and a 160 rear.
  35. #33
    Join Date
    Dec 2010
    Location
    TN
    Posts
    2,447
    Default
    Next time around on tires, do the 160 rear with that 5". Better selection to choose from too.
  36. #34
    Join Date
    Jul 2009
    Location
    Northern utah
    Posts
    4,682
    Default
    Throw the 120 and 160 on there and you'll realization how much you're handicapping yourself with the improper sizes.. even just riding on the street
  37. #35
    Join Date
    Sep 2011
    Posts
    33
    Default
    Yea, I'll try it for sure, I just got a couple sets of these off my buddy for $100, couldn't pass it up. Should I try pilot race again or go for a supermoto tire setup?
  38. #36
    Join Date
    Jul 2010
    Posts
    150
    Default
    Looks like the bike was a steal man! the turn signals definitely were not though...
    Fast is smooth. Smooth is Fast.
  39. #37
    Join Date
    Sep 2011
    Posts
    33
    Default
    Tried it out for a little while and switched back to dirt until I get my hands on some rotors that fit. Still works good in the mud... Have to get my new meat claws mounted tomorrow to really dig deep.
  40. #38
    Join Date
    Sep 2011
    Location
    north west orange county kommifornia
    Posts
    349
    Default
    on your rear pressure switch guide the wire under the subframe were it mounts into that frame bracket and out through the top against the frame and presto no wire melting worries. you have a ton of space between that subframe bar and the mounting area on the frame
  41. #39
    Join Date
    Sep 2011
    Location
    Posts
    349
    Default
    i see your having trouble with your rotors. i was in the same boat just with the front the bolts that they sent were no were near the right bolts for my rotor. best bet is to take it to a place that builds wheels "dubyausa.com" which i did their going to machine my rotor/bolts to fit exact. these people are the main importers/builders "they have a shit ton of talon sprockets btw" for talon excel here in california and were actually building some dope ass wheels for the hart and huntington supercross bikes when i came in. very clean shop and very nice helpfull people id suggest giving them a call at 1714 279 0200 . they took care of me in a heartbeat and actually were concerned in the difference in bolts that i recieved from talon. even with supercross going on and will have it ready for me in the morning before 12
  42. #40
    Join Date
    Sep 2011
    Posts
    33
    Default
    Back on the build, have a set of moto master rotors on the way to see how they fit up, 320mm front. Hopefully they'll be in next week. Deals gap trip coming up soon so I can finally try it out for real.
  43. #41
    Join Date
    Sep 2011
    Posts
    33
    Default
    Rotors came in the other day and once again, the rear rotor is too large in diameter to roll in the caliper and the front caliper bracket is just wrong. But the front rotor fits great.
  44. #42
    Join Date
    Jul 2009
    Location
    Northern utah
    Posts
    4,682
    Default
    If your front caliper isn't lining up, chances are the bracket was made to relocate the caliper to use with an OEM 320 brake rotor. They are offset outwards about 3.5mm.
    Ypu need a rear rotor from a 2005 and older. They are slightly smaller in diameter. I think I have one if you need it? I also have a front brembo SM brake setup. From an older Husky with 45mm forks like yours.
  45. #43
    Join Date
    Nov 2011
    Location
    Auburn, Al
    Posts
    146
    Default
    Looks like we are both having troubles. I just did my compression check and its not looking good. tearing engine down now. going to need more work than I thought. Hopefully we are both done the rally.
  46. #44
    Join Date
    Apr 2011
    Location
    Gold Coast Australia
    Posts
    164
    Default
    Awesome build there, I'm in the process of doing the exact same thing but with an 04 450SMR, I'm putting a 510 engine in mine and doing the 06 plastic swap can't wait to finish it!
    sold- 2005 KTM 450EXC street and track tard
    sold- 2007 Honda CBR600 road bike
    sold- 2006 Husqvarna SMR510 race tard
    sold- 2005 Suzuki GSXR750 track bike
    current- 2008 Yamaha yz450f race tard
  47. #45
    Join Date
    Sep 2011
    Posts
    33
    Default
    Dang, that would be sweet! So are you going to do an oversize tank? If so I guess we just get one for an 06 husky so the plastics match up? I want to swap to 06 plastics as well and do all black. I've been looking at tanks on halls husqvarna in Springfield IL and they have a few to choose from.
  48. #46
    Join Date
    Sep 2011
    Posts
    33
    Default
    Quote Originally Posted by J.R. View Post
    The guys at motostrano said they had another rotor to send me that is smaller for the older models and a different caliper bracket. I'll let you know though, I might be interested if this does not work out.
  49. #47
    Join Date
    Sep 2011
    Posts
    33
    Default
    I just saw in another thread of yours that we just have to swap our tank and seat to the 06 version and the plastics will work, thanks.
  50. #48
    Join Date
    Apr 2011
    Location
    Posts
    164
    Default
    Yeah mate that's correct seat plastics and they all fit I'm finding it hard to find a seat and tank in Australia at the moment going to look around at wrecking yards this week
  51. #49
    Join Date
    Sep 2011
    Posts
    33
    Default
    What do you guys do about a 120 rubbing the inside of your forks? And I have a 5" rear and it is tight with a 150. I put my buddy's 4.25 and 160 on and it clears better than mine.
  52. #50
    Join Date
    Sep 2011
    Location
    Posts
    349
    Default
    the brand and model tire can be an attributing factor to your problem just because it sais the size doesnt mean its the same as another companys or model tire there have been a couple threads regarding this so check around and maybe by switching tires your problem may be solved
  53.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
