3 way tire Comparo! .......... Conti vs 2ct vs Q2
Results 1 to 38 of 38
Thread: 3 way tire Comparo! .......... Conti vs 2ct vs Q2
  1. #1
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default 3 way tire Comparo! .......... Conti vs 2ct vs Q2
    Link to the blog: http://socalsupermoto.com/blog/2011/...re-comparison/
    We have 3 nearly identical drz400sm's, all fitted with fresh tires, so we're in a unique position to do a 3 way tire comparrison! All were fitted with 120/70 - 160/50 tires running 22f/24r tire pressue. I did 8 back to back laps on each of the bikes.
    These tires are so close performance wise, that the fastest lap times will come down to the tires that you have the most confidence in. For that reason much of this review will be rating the tires on subjective "feel" of each.
    Warmup
    Evaluating warmup times is easy. All I do when I warm up my bikes for my students is run laps until I start getting squeling/chirping from the rears while on the brakes. As soon as I start hearing the rear hook up, that's when I bring the bike in and start warming up the next one.
    1) Pilot Powers 2ct - Warm up quick! within two laps these start hooking up. They are by far the tire that I have the most confidence in while cold. By far the fastest warm up tire, which has a huge advantage for street riding since lightweight supermoto bikes often have a hard time with warm up. Winner.
    2) Dunlop: The dunlop took about 4 laps to get up to temp. Not bad, not great, not a particular worry.
    3) Conti's: Took about 4-5 laps to get some heat in them. However while the other bikes had a trackday on em, the conti's only had a street ride. So the tires may have been still working on getting some flex into them. We'll call it even with the q2's on warmup.
    On the brakes:
    1) Pilot Powers 2ct: I liked the feel I got from the rear tire on the 2ct's. While sliding (I'm not a big backitiner) the tire had good feel, and you could tell where it was and what it was doing. Transitioning from the brakes into the turn was also very good. The front did not feel as stable as the q2, but still very good. Winner
    2) Q2: The rounded profile of the dunlop felt a bit more stable getting hard on the front brake. It still dipped in well. Perhaps the pressure at 24 was too high, or maybe it had something to do with the suspension, but I didn't have the feel for the rear like I did with the 2ct's. I'd let out the clutch fast, and didn't feel like it was hooking up and giving as much engine braking. It fell like I had a clutch that was slipping and not providing the compression braking. I didn't experience this on the same bike with other tires.
    3) Conti's: Same exact thing as the q2's. It didn't feel like the rear was hooking up as much on the brakes, and didn't have as much feel from the rear tire as the 2ct.
    student Alex having fun:
    Flickability
    1) Power 2ct's: Due to their profile, these are exactly halfway between a very v dunlop slick and a roundish street tire like the q2. It flips relatively easy from side to side and then once there likes to stay there. It was also the easiest to change lines mid turn. Ruling is very flickable but not too much to not feel stable. Winner.
    2) Dunlop: These were the least flickable of the batch. The flipside is that they felt rock solid and very stable mid corner. Steering is the most predictable with these. They didn't feel like they were going to give you any surprises. I suspect this is due to more rubber overall and the more round profile. They definitly felt like a heavier tire. Winner if you prefer and nice stable tire.
    3) The most flickable of the batch. The tire looks roundish when you look at them, but I suspect this is due to the circle pattern of the tread. On the bike they feel very light and flickable. The front end felt very light and not as planted as the others, but it was a piece of cake to throw into a turn. My guess is that these have less rubber on em than the q2's, This would fit with their reputation as a good tire that tends to wear a bit quicker than others. Winner if you simply want the lightest feeling tire of the group. I still prefer the 2ct.
    Grip:
    I'm still nursing a rotator cuff injury, so grip was evaluated at a very spirited track pace, not race pace. I did ride hard enough to get occasional slips, and enough to evaluate overall feel and trust in the tires.
    1) Power 2ct's: Great grip. As mentioned at the start of this review, how fast you'll be will depend upon your trust in the tire. The 2ct's always felt nice and planted. Only downside is that after ridden very very hard on a hot day, they're know to get "greasy". I didn't run enough laps to experience this, and can only experienced this after 20 or so laps on a very hot day. On the street this would be a non issue, and could probably be solved on the track by running a few extra psi. Grip was very good, and when it did step out on the gas it did so in a very predictable way. The tire was very confidence inspiring. Winner.
    2) Q2's: Also very very good grip. Only reason it's not a winner is because it didn't seem to have as much feel as the 2ct's. On the high speed sweeper it did feel very planted. No problems here, great grip.
    3) Conti's. Also had good grip, but didn't feel as planted. On the highspeed sweeper I could feel a little push/chatter from the front which made me back off it a little bit. While running wide I didn't have the confidence in the grip to push it down to correct the line. Still overall, sticky tire I just preferred the grip of the others.
    Feel:
    The 2ct's were the best compromise of feeling both flickable and planted. The conti's had good grip and felt very light but didn't feel as planted. The q2's felt nice and planted but were harder to feel what the tire was doing vs the power 2ct's. Overall winner: Michelin pilot powers 2ct, The only tire I like as much are the supercorsa's which is a great tire but are twice the price.
  2.
    Advertisement
  3. #2
    Join Date
    Aug 2004
    Location
    Pacific Northwest
    Posts
    9,673
    Default
    great comparo....great thread ! question... you had mentioned they were all the same size as well profile, but you refered to some tires as being rounder or a different profile which conflicts with the title all being the same....are you finding the same with what we have found over the years for sizing...? that one mfg's tire profile is different from another... so a 120/70 from one is different than that of a different mfg...? are the three sets you put on the bikes all about the same price... BTW BRAVO on your school... it looks to me that you have done a excellent job and have seen some great growth... keep up the good work B although I hate you because you can ride in 80 degree weather while we are freezing our @@##**%% off....
    hope you don't mind but this thread is more than worthy to be stuck,
    Brian # 30
    KTM 450 SMR
  4. #3
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    Quote Originally Posted by brian View Post
    I understand your confusion. I used the term profile two different ways. one way as describing the tire dimensions, ie 120/70. But also used profile to describe the actual shape of the tire. Ie the 2ct's and q2's have the same tire size/profile 160/60, but have a different profile shape, ie V shaped vs D shaped. The tires despite the size description aren't the same widths. The q2's are the fattest with lots of chain rub. next widest is the conti's that barely touch the chain, then the 2ct's which have some good clearance. I don't worry about it anymore, I run 160 regardless of manufacturer and actual size.
    The school is going great! It's a lot of work, and I won't get rich but every day I go to the track is one less day I go to my "real" job. I don't actually get to ride much, but get a few laps in warming up the bikes, then a few more in the afternoon showing lines. Summer gets insanely hot since it's basically out in the desert, plenty of 100+ days, but now is perfect. Last wednesday was 76 and sunny all day! Plus with recent rains the dirt hooks up nicely. I think my clients finally figured this out cuz we're doing 5 trackdays in 3.5 weeks. There's a bike gassed and ready for you if you wanna fly down for a weekend and play!
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    I added the grip assesment of the conti's. Also I tried another bike with bt003rs, which is a tire I used to run. Same feelings as our earlier review. Basically that it has good grip and wear but has crap feeling. You can't tell what that tire is doing!
    http://socalsupermoto.com/blog/socal...t003rs-review/
  7. #5
    Join Date
    Aug 2004
    Location
    Pacific Northwest
    Posts
    9,673
    Default
    Perfect Thanks B ! It's funny how much wider DOT's are from Slicks...next time at the track I'm gonna measure each brand and see who is smokin what... great info on the profiles after all the reading i should have assumed that
    I'd love to come down.. I have only been threatening you for 5 years now....My dream is to pull off my canopy and load the bike no trailor and grab the wife and header....
    Thanks again for the great info..will chat soon.. sorry to thread jack..
    Brian # 30
    KTM 450 SMR
  8. #6
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    Least popular sticky of all time
    had another trackday testing all three tires. Despite this picture, the conti's are by far the weakest on grip according to myself and students.
    The most predictable, sticky and trustworthy tire goes to the q2, and fave is the 2ct due to how happy it is layed over and it's ability to quickly flick from side to side.
  9. #7
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    I don't know if they needed more heat, of more flex to be worn into the tire, but after 3/4 trackdays the q2's have become my new favorite. They are stable, still flickable, and stick like poo to carpet. Now all that's left is to see how they wear compared to the 2ct's.
  10. #8
    Join Date
    Aug 2010
    Location
    Lake Norman, NC
    Posts
    61
    Default Mind changer
    I was about to order the continentals but I guess I am gonna get the michelin since they came in second and they are the cheapest at rockymountainmc.com. What about tire wear? Which ones would you say last the longest? I run mine until i am sliding on wires so I feel like i am getting full use of them.
  11. #9
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    Quote Originally Posted by motomarc View Post
    2ct's wear very very well. I've done 6 months of trackdays on a pair. Conti's have a reputation of going off pretty quick. I havn't worn through q2's yet but they're rummored to wear pretty quick which makes sense given the stick. you won't regret the 2ct's at all.
  12. #10
    Join Date
    Aug 2010
    Location
    Lake Norman, NC
    Posts
    61
    Default
    Cool, thanks for doing the test for us rookies! My buddy has the conti's so hopefully i will be passing him on the outside while flipping the bird.
  13. #11
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    don't get too confident, here's another pic of the conti's in action
  14. #12
    Join Date
    Aug 2010
    Location
    Chicagoland
    Posts
    169
    Default
    /\ /\ It just might be that that rider has a some maaaad skills!!!! /\ /\
  15. #13
    Join Date
    Oct 2011
    Location
    30 mins from Deals Gap, TN
    Posts
    520
    Default
    Good info - sounds like the conti's will be my hooligan set of tires (came with spare rims)
    http://s96.photobucket.com/albums/l1...905_035653.jpg
    Join the riding game!
    Challenges Met - I lost count a long time ago!
  16. #14
    Join Date
    Mar 2011
    Location
    Verona, Va
    Posts
    471
    Default
    Awesome thread!!
    How are they holding up as far as wear?
    Instagram: @iwannagofast823
  17. #15
    Join Date
    Jun 2011
    Posts
    9
    Default Shinko 008 race tire
    Has anyone ran the shinko 008 slick and have any feed back on it. Thanks
  18. #16
    Join Date
    Aug 2005
    Location
    San Diego, CA
    Posts
    577
    Default
    I always like Cont, and now the BTO23 is my fave for price, wear and performance for the buck! Great street (palomar)/Commuter tire.
    2006 DRZ400SM
    2006 CRF450R
    1997 XR650L
    Yup, U just got passed by a 32 hp Dirtbike with street tires! Classic!
  19. #17
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    General followup:
    Conti's still suck, they have the least tire feel and tough to get heat in.
    powers are solid performers, but next time around it'll be q2's on all the bikes. They take 1.5 laps longer to get heat in em, but they stick great, seem to wear well for our purposes, are cheap, and have awesome feedback and feel. Q2 for president
  20. #18
    Join Date
    Apr 2012
    Location
    Denham Springs, Louisiana
    Posts
    27
    Default
    Ok so don't get mad at for saying this because I really do say this with kindness and respect from the bottom of my heart. I REALLY HOPE YOU GET DIARRHEA! While I'm stuck here in southern Louisiana, bike less, your in SoCal riding whatever freaking bike you want, whenever you want! Oh not to mention the occasional manufacturer that stops in and says "Hey guy, here's my new bad ass bike for you to ride with all the bad ass crap we could think of for you! Oh nah! Don't worry about money! Just write us a review and have fun!" while in the meantime, it's 10 degrees cooker than hell here with tornados and hurricanes and humidity that is horrible! And I haven't bought my next bike yet! But I don't want to sound jealous or complain and I really do mean that diarrhea thing in the nicest way possible!
  21. #19
    Join Date
    Apr 2011
    Location
    Bend, Oregon
    Posts
    126
    Default Which Conti?
    Are you comparing the Conti Force? or the Conti Attack SM? I hear they're quite different tires. I've got an Attack SM on order for the DRZ "e" 150/60, hope it's more predictable than the batlax 016 -160/60 that I'm taking off.
    Scott - Bend, Or.
    2006 Ktm 450 smr
    2000 DRZ 400e
    2014 Triumph Street Triple R
  22. #20
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    Quote Originally Posted by GracieBarraMotard View Post
    Don't forget that sometimes we have to share the track with annoying guys like Max Biaggi and Josh Hayes
  23. #21
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    Quote Originally Posted by melovelo View Post
    They're the older conti sm's which I think were the force. The sm tire but not the new attacks. The 016's are a good tire but too hard to get heat in. Bottom line is that I'm done with everything, and just running q2's on all my bikes now. That tire lasts, sticks, warms up quick, good predictable feel, and is cheap. WIN!
  24. #22
    Join Date
    Apr 2012
    Location
    Posts
    27
    Default
    Quote Originally Posted by bdmmotard View Post
    Oh wow than that just changes everything!!!! You have to share your world class track with annoying superbike world champions!!! Man I really feel sorry for you buddy!!! Lol!!! But being serious, I truly do envy you! It must be awesome to earn a living doing something you absolutely love!!! Thanks for the comparison too!
  25. #23
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    Well socal supermoto is just one of my two full time jobs (other is shooting ct scans). But yeah, I completely understand how lucky I am and don't take any of it for granted. I honestly look forward to every school day, and am super grateful to everyone that supports us.
  26. #24
    Join Date
    Apr 2012
    Location
    Posts
    27
    Default
    Even though riding takes a back seat to Brazilian Jiu Jitsu for me, any one that us an ambassador to a sport that is as pure as motorcycles and fighting and does his/her best to pass on their knowledge, experience, and passion to every person possible that they are able is a good person and hell, I'll even say a role model (aw shucks! I've never been so sentimental and crap before!). Now with that bring said and I've actually been nice for a little bit, I am a secret ninja, snuck in to your work while you were shooting a cat scan and put a few drops in your soda to make sure your diarrhea is imminent!!!! Muahahaha!
  27. #25
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
  28. #26
    Join Date
    Mar 2011
    Location
    charlotte NC
    Posts
    24
    Default
    man i wish i read this before i bought the conti SM attack? i was running pilot powers for street use and decided to buy a set of track only tires and went with the SM attacks cause people were saying great things about the SM attacks over the conti force.. this is the only really thing ive read that has compared tires in a track style test. the only thing i did notice about the pilot powers on my front is that they would feel like they wanted to slide out the grip. i was getting a little sketchy about that. it was a low speed tight turns that it would do that. not sure its because of my riding style or what? but anyways i hope they arnt as bad as you say they are....
  29. #27
    Join Date
    Apr 2011
    Location
    Bend, Oregon
    Posts
    126
    Default Conti-Attaci sm (new model) feedback
    My last track day I had just switched my rear from a Battlax 016 160/60-17 to the new Conti-attack SM 150/60-17.
    I live in the NW, and air temp started at about 50deg up to about mid 70's- finally a sunny dry day.
    I didn't have a single issue with lack of grip once warm-up was achieved.
    I was running 19 PSI. Tire feedback was GREATLY improved over the Battlax.
    I'm still using the 016 up front and so far, so good.
    I may change the front eventually.
    Never used Pilots, so I cant comment on those.
    Scott - Bend, Or.
    2006 Ktm 450 smr
    2000 DRZ 400e
  30. #28
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    I wouldn't sweat the conti attacks, I was reviewing the old tire and from what i've heard the attacks work well.
  31. #29
    Join Date
    Sep 2009
    Posts
    1,439
    Default
    i just found that out myself on the widths, i was running a bridgestone 165 slick and cleared the chain fine, when a switched to the conti sumo 160 dot tire and the chain was all over the tire....
  32. #30
    Join Date
    Dec 2011
    Posts
    220
    Default
    Any weights of the different tires? Which is the lightest of the bunch?
  33. #31
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    Quote Originally Posted by Mr.P View Post
    Sorry, didn't weigh em. The q2's we use now feel relatively light.
  34. #32
    Join Date
    Aug 2004
    Location
    Pacific Northwest
    Posts
    9,673
    Default
    This Conti back tire looks like it lacks surface area, too much tire pressure, might be the reason why its taking so long to heat up...did I read that someone dropped the PSI down to 19 ? If so those side walls have no flex, these tires would prolly work better with a 70's profile rather than a 60's that actually look like a 50's
    Brian # 30
    KTM 450 SMR
  35. #33
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
  36. #34
    Join Date
    Mar 2006
    Posts
    239
    Default
    On my 690 I have gone through 1 set of Conti SM (rubbish tyre sliders everywhere at the track) to 4 sets of Q2 now recently I have fitted Q3 and wow theyre an amazing tyre!
    The candle that burns twice as bright burns twice as fast
  37. #35
    Join Date
    Sep 2009
    Posts
    1,439
    Default
    Quote Originally Posted by nitronaf View Post
    who makes the q2 & q3/ thx, rm
  38. #36
    Join Date
    Aug 2004
    Location
    San Diego
    Posts
    6,386
    Default
    Quote Originally Posted by ratman View Post
    Dunlop!
    Good to hear some other input so I know it's not just in my head. q2 and q3s are truly amazing tires for the price.
  39. #37
    Join Date
    Sep 2009
    Posts
    1,439
    Default
    what do they get for a pair of q3's?
    i have been running the bridgestones med rear, soft front on my street bike, berg fs 570, i love them but they are a bit pricey. thx, rm
  40. #38
    Join Date
    Aug 2006
    Location
    Gold Coast, Qld, Australia
    Posts
    7
    Default
    After finding this thread
    Decided to try the Dunlop Q2's and loving them.
    Priced to sell also.
    The Q3's come out here in Australia next month
    Will be keen to give them a go also.
    Thanks
  41.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
