Tech Inspection
Results 1 to 9 of 9
Thread: Tech Inspection
  1. #1
    Join Date
    Feb 2005
    Location
    Northwest
    Posts
    614
    Default Tech Inspection
    Everyone, I'm the Tech Inspector this year and Brian is my trusty assistant. Below is the list of requirements from the rule Book.
    1. Drill and safety wire oil drain plugs and filler caps – may substitute with silicone sealant or equivalent.
    2. No leaking fluids of any kind; oil, water or fuel.
    3. No antifreeze in cooling system; wetter water or equivalent ok.
    4. Carb and fuel overflow hoses MUST be routed into a suitable catch container – radiator overflow recommended.
    5. Number plates must be securely attached and be easily read from 50 feet.
    6. Remove kickstand – mini classes may retain kick stand if secured.
    7. Wheels and tires in race condition; no loose spokes, flat or damaged tires.
    8. Throttle operates freely and smooth.
    9. No loose parts.
    10. Lights and turn signal indicators should be removed; tape over glass head lamp ok.
    11. Properly mounted peg sliders are mandatory; and other devices that protect the racing surface such as axle sliders are HIGHLY encouraged.
    12. Failure to abide by the technical regulations may result in not passing technical inspection and not participating in the race event.
    Saturday afternoon 3:30-5:00PM tech will be open. This is the preferred tech time as we will all be in a rush Sunday morning.
    Sunday morning, tech will be open 8AM-9AM (Practice should start at 9AM).
    Tech will be in the hot pits. Look for the Tech sign.
    No bikes may enter the track any time Sunday without tech sticker. Bikes having gone through tech on Saturday do not have to be inspected again on Sunday.
    Also note that sound checks will be done this weekend. This will not be part of the tech inspection but will be done during practice and during race day.
    See you at the race.
    PLammer #73
  2.
    Advertisement
  3. #2
    Join Date
    Feb 2005
    Location
    Sedro Woolley,WA
    Posts
    604
    Default
    what if nobody makes peg sliders for our bikes (Kawasaki) not just my little one but all the big ones im bringin down. any suggestions????????
    Was it worth it ?
    NORM 908
    Homeless Champion
    2008 Skagit Valley , Monster Energy, Fly Racing, Kawasaki KX250F
  4. #3
    Join Date
    Feb 2005
    Location
    Northwest
    Posts
    614
    Default
    Yeah. good point. For the minis, I need to find out if we're going to enforce the sliders on them. Might be just for 200cc + bikes. I leave the final word on that to Ron and Kurt.
    For any bikes that sliders aren't made for, cut a piece of plastic, drill a couple of holes and zip tie them to the bottom of the foot pegs. Make sure the zip ties are inboard of the peg so they won't wear as the day progresses. Ron said he'll have some plastic at the track that people can do this with, but prolly best to get it done ahead of time.
    For a place to buy the plastic, I suggest TAP Plastic. That's where I buy mine for my boot sliders.
    Plammer #73
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Aug 2004
    Location
    Snohomish, WA
    Posts
    1,320
    Default
    Quote Originally Posted by norm908
    what if nobody makes peg sliders for our bikes (Kawasaki) any suggestions????????
    Buy a new bike?
    You should be able to buy some small pieces of UHMW and make a simple peg slider.
  7. #5
    Join Date
    Feb 2005
    Location
    Sedro Woolley,WA
    Posts
    604
    Default
    [QUOTE=motarded]Buy a new bike?
    why, mine seems to be in front of yours quite often???? oh big bikes, right..... i got 3 of them this year.
    Was it worth it ?
    NORM 908
    Homeless Champion
  8. #6
    Join Date
    Feb 2005
    Location
    Northwest
    Posts
    614
    Default
    OK, I spoke w/ Ron and Kurt, for the mini class bikes, peg sliders are not required. They're only required for the big bike classes.
    PLammer #73
  9. #7
    Join Date
    Feb 2005
    Location
    Sedro Woolley,WA
    Posts
    604
    Default
    Thanks Paul!
    Was it worth it ?
    NORM 908
    Homeless Champion
  10. #8
    Join Date
    Oct 2004
    Location
    Snohomish County
    Posts
    1,737
    Default
    Having done some Tech inspections last year... and hearing loads of excuses, etc...
    The biggest problems I found were 1)lack of catch cans, and
    2) sticking throttles!
    A sticking throttle is bad, bad, bad...
    It's pretty simple, if your throttle does not return on it's own,
    you've got a problem and you should not, will not, be allowed on the track.
    For your own safety, as well as, everyone else's.
    However, if you do get in a bind with something, ask around...we are all willing to help someone out when in need.
    (I usually have a good supply of zip-ties, duct tape, safety wire, etc)
    RogerB
    RogerB#39,
    2010 'Berg FX450
    2013 Sponsors:
    http://www.vinaccio.com/
    Great people, AWESOME coffee!
    http://www.axorace.com/
    http://www.fmfracing.com/
  11. #9
    Join Date
    Mar 2005
    Location
    York SC - just below Charlotte
    Posts
    8,613
    Default
    Fuel, Coolant & Crank case contaiment tanks are availible from www.AdvancedPerformanceAccessories.com
    *** AMA Pro Racing approved ****** The Official Catch Tanks of NASMOTO ***
    www.MotoHose.com
    Don't bring a gun to a snowball fight!
  12.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
