14 ktm 500 exc black gas tank?
Results 1 to 11 of 11
Thread: 14 ktm 500 exc black gas tank?
  1. #1
    Join Date
    Jul 2007
    Posts
    12
    Default 14 ktm 500 exc black gas tank?
    Has anyone ever tried swapping a 14 450 sx-f gas tank? Ktm part number 7890701314430. Was wondering if this is compatible with the 500exc
  2.
    Advertisement
  3. #2
    Join Date
    Jul 2013
    Posts
    10
    Default
    Yes it does. I have a SXF tank on my EXC supermoto. Straight swap.
  4. #3
    Join Date
    May 2011
    Posts
    46
    Default
    Quote Originally Posted by Max460 View Post
    does this work on the 2012s?
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Jul 2007
    Posts
    12
    Default
    The 2012 have different plastics so it might not match up. Check ktm-parts.com they have tons of oem parts and good customer service
    The picture above looks like a 2012 exc. So I'm sure it will work.
  7. #5
    Join Date
    May 2011
    Posts
    46
    Default
    Quote Originally Posted by tibbs View Post
    cheers. I think there may be an issue with compatibility of fuel pumps or at least the routing of the fuel between the EXC and SX models
  8. #6
    Join Date
    Jul 2012
    Posts
    4
    Default 500 xcw sxf tank
    I am looking to put the sxf tank on my xcw but have heard there would be issues with the radiator fan. Does it have to be removed/relocated?
  9. #7
    Join Date
    Jul 2005
    Location
    Chicago
    Posts
    1,276
    Default
    Do a search it has been mentioned and done before with swapping the fuel lines an other parts with that year and tank combo.
    2014 KTM 1290R SuperDuke
    2012 KTM 500 Sumo
  10. #8
    Join Date
    Dec 2014
    Location
    UK
    Posts
    141
    Default
    i did this a few months ago on my 450, but its pretty similar apart from the fuel lines
    yes you need to remove the fan and either leave it off or refit it lower down on the rad
    i left it off because ive never had a overheat issue, ever! even on my old ktm's.
  11. #9
    Join Date
    Jul 2012
    Posts
    4
    Default
    Thanks for the reply Lloyd. I think I am going to try to move the fan down. Wouldn't think it would change the effectiveness of the fan too much. Like you said though mine has hardly ever kicked on in the past. Don't have the tank in yet it is currently back ordered. Any idea on how far down the fan would need to be moved?
  12. #10
    Join Date
    Dec 2014
    Location
    UK
    Posts
    141
    Default
    you can view my post and rrrr1rob who was a big help to me, good guy.
    below
    http://supermotojunkie.com/showthrea...t=#post1882122
    also you will need to atleast buy two fuel lines if for the 500
    ktm numbers Fuel line x 2. Part # 77207016000
  13. #11
    Join Date
    Jul 2012
    Posts
    4
    Default
    Sounds good. I'll make sure to order the lines then. Didn't know if they would flip flop like you mentioned in one of your previous posts. I think I am either going to first try to just make extensions to lower straight down from the existing fan mounting holes on the bracket or if that isn't sufficient I will drill out the existing rivets, remove the bracket and extend the existing mounting points on the bracket to drop the entire bracket while still using the existing rivet holes. Ha hopefully that makes sense. Thanks again
  14.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
