CR500AF Supermotard Project (because Canadian winters are cold)
Results 1 to 42 of 42
Thread: CR500AF Supermotard Project (because Canadian winters are cold)
  1. #1
    Join Date
    Jun 2013
    Posts
    33
    Default CR500AF Supermotard Project (because Canadian winters are cold)
    2004 CRF450R frame with a 1997 CR500 motor. Street legal.
    VIDEOS
    https://www.youtube.com/watch?v=C7Ty...ature=youtu.be
    https://www.youtube.com/watch?v=GIlA6_WHY9s
    Weight 224 lbs dry weight with 72HP.
    Pro Circuit expansion chamber
    FMF slip on
    Boysen power reeds
    Service Honda digital ignition
    Warp 9 supermotard rims
    Sprocket gearing 15F 40R (38R for longer rides)
    Conti Attack supermotard tires
    Trail Tech kick stand
    Trail Tech Vapor computer
    All new Hot rods bearings and seals
    Billet aluminum upper clamps
    Pro Taper CR high rise bars
    Pro Taper diamond grips
    Vancouver Supermoto wiring harness (Warness)
    KTM headlight with H4 LED bulb conversion
    K&N air filter
    Welding, frame fabrication, and radiator welds all done by Armstrong Motors in Kingston, Nova Scotia.
    Pro Tech Suspension, full rework. Done by Lee Tinkler in Montreal, Quebec. (Lowered 1.5 inches)
    Keihin 39mm PWK carb (Current jetting is 48 pilot jet and 175 main jet with needle clip in the 3rd position)
    NGK BPR7ES spark plug
  2.
    Advertisement
  3. #2
    Join Date
    Jun 2013
    Posts
    33
    Default
  4. #3
    Join Date
    Jun 2013
    Posts
    33
    Default
    The donors
    Quickly stripped and ready to cut
    Warp 9's arrive
    Motor lands safely on Canadian soil
    Cutting and welding
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Jun 2013
    Posts
    33
    Default
    Motor prep
    New piston (OEM)
    Lectron smart carb (operates with a jetless system)
    Pro Tech Suspension (done by Lee Tinkler) Lowered 1.5 inches
    Decompression valve fabricated, welded, and head shaved.
    First mackup
    Radiator fabrication
  7. #5
    Join Date
    Jun 2013
    Posts
    33
    Default
    Big shout of to Vancouver Supermoto for building the "warness" on my motard. It made wiring the entire bike so simple. Plug and play, literally.
    Gas tank molding (this was one of the more difficult parts of the build).
    Head stay mounts and brackets
    Graphics done by Stickman Graphics in Tennessee.
  8. #6
    Join Date
    Jun 2013
    Posts
    33
    Default
    I'm still working on the jetting. After about 250 miles of riding I'm still running a little rich. Jetting this monster is a slow and expensive process.
  9. #7
    Join Date
    May 2015
    Location
    liquor store
    Posts
    1
    Default
    my Rav could beat that filthy cr5 in a race any day of the week
  10. #8
    Join Date
    May 2009
    Posts
    157
    Default Jetting
    I thought you were using a lectron carb? You just adjust needle position don't you? What size lectron does a 500 use?
  11. #9
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by mod40car View Post
    I was running the 40mm Lectron but I could never get it to idle right. I went back to a PWK.
  12. #10
    Join Date
    Jul 2010
    Posts
    716
    Items for Sale
    Default
    Did you weld that stuff? If yes, you got some mad skills!
  13. #11
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by 570rr View Post
    I wish I could tig like that! This was done by a local motor fabrication company that builds race engines and have done some work for Nascar teams. They do really great work and this was their first two stroke project.
  14. #12
    Join Date
    Nov 2013
    Posts
    27
    Default
    Please post a video if you get a chance. This was done right and looked beautiful.
  15. #13
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by crimsononly View Post
    Thanks!! Here are two really poor quality videos that my friends have made with my footage. I'll compile all of my footage soon and post it up.
  16. #14
    Join Date
    Nov 2013
    Posts
    27
    Default
    Looks and sounds excellent. Very good work.
  17. #15
    Join Date
    Jun 2013
    Posts
    33
    Default
    looks and sounds excellent. Very good work.
    thank you!
  18. #16
    Join Date
    Jun 2013
    Location
    Helena, Mt
    Posts
    118
    Default
    What are you running for sprockets?
  19. #17
    Join Date
    May 2015
    Location
    Northern Arizona
    Posts
    12
    Default
    My favorite sumo build.. love to see these.
    Subscribed
  20. #18
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by Azprc View Post
    Right now I'm running a 15T front and a 40T rear. I've done some experimenting with different gearing and this seems to be the perfect combination of torque and speed. It will still lift the front in every gear but will also cruise at 80mph at about 4100 RPM.
  21. #19
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by FREESTYLEKYLE View Post
    Subscribed
    Thank you!!
  22. #20
    Join Date
    May 2015
    Location
    Northern Arizona
    Posts
    12
    Default
    I would love to do the same thing with a kx500/kfx450.... Always been a Kawaholic.
  23. #21
    Join Date
    May 2014
    Location
    Norway
    Posts
    9
    Default
    So nice!
    If you ever want to part with it, PM me
  24. #22
    Join Date
    Jun 2013
    Posts
    33
    Default
    A KX500AF supermoto would be awesome!
  25. #23
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by checkit View Post
    so nice!
    if you ever want to part with it, pm me
    Will do, sir!
  26. #24
    Join Date
    May 2015
    Location
    Northern Arizona
    Posts
    12
    Default
    Quote Originally Posted by brodster12 View Post
    You can build me one, I'm not sure I have the skills and patients...
  27. #25
    Join Date
    Feb 2015
    Location
    UK
    Posts
    58
    Default
    Excellent build
    Very tidy
  28. #26
    Join Date
    Jun 2013
    Posts
    33
    Default
    I would love to!
  29. #27
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by Capz85 View Post
    Excellent build
    Very tidy
    Thanks!
  30. #28
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by Checkit View Post
    So nice!
    It's for sale
  31. #29
    Join Date
    Jun 2013
    Posts
    33
    Default
    Bondi Engines in Toronto, just did a full motor rebuild to include Crank, seals, bearings, Weisco Piston (drilled), and brand new OEM cylinder. All just preventive maintenance.
    If you've never used Bondi Engines, I'd highly recommend them. The high level of professionalism and workmanship is bar none. They are undoubtedly the best two stroke engine builder in Canada and with the Canadian dollar so low, it should be all that more appealing for US based customers.
  32. #30
    Join Date
    May 2007
    Posts
    22
    Default
    It's for sale
    Don't! You will regret it, I do
  33. #31
    Join Date
    Dec 2015
    Posts
    3
    Default
    Hey man I see you're a nova Scotian, I'd love to see that bike in person sometime
  34. #32
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by Captain Licorice View Post
    Where are you in NS?
  35. #33
    Join Date
    Dec 2015
    Posts
    3
    Default
    In between Antigonish and Sherbrooke, yourself?
  36. #34
    Join Date
    Jan 2016
    Location
    Denmark
    Posts
    10
    Default
    Awesome build. I love when you bring life to the old smokers
  37. #35
    Join Date
    Sep 2012
    Location
    Vaudreuil (Montreal, Canada)
    Posts
    1,931
    Thumbs up
    Sweet ride!!!
    How did you get it plated in Canada? As far as I know, it's now impossible to plate an offroad vehicle here in Canada.
    '15 Silver FZ09 (current)
    '09 690 SMC / '10 WR250X / '96 CR250 / '88 RM80 (sold)
    Riding Game: 3
  38. #36
    Join Date
    May 2011
    Location
    New Zealand
    Posts
    554
    Default Bump
    Bump
  39. #37
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by Oldie 30 View Post
    Bump
    Glad you could join the party, Oldie! In about 1.5 months I'll have the weather to demonstrate a 200 KPH run. I'll plan to have a GoPro on board for the GPS run. I would like to make a serious bet with you. If I can achieve 200KPH and prove it by whatever means we can agree to be reasonable, you PayPal me $100 USD. If I fail to do so within an agreed reasonable amount of time, I'll PayPal you $250 USD.
    Let me know what ya think old fella, can you put your money where your mouth is?
  40. #38
    Join Date
    Jan 2017
    Posts
    3
    Default
    It's for sale
    Do you still have it up for sale?
  41. #39
    Join Date
    Jun 2013
    Posts
    33
    Default
    Quote Originally Posted by AdamBoy View Post
    Yes
  42. #40
    Join Date
    Jan 2017
    Posts
    3
    Default
    Yes
    Is there an email address I can contact you on?
  43. #41
    Join Date
    Jun 2013
    Posts
    33
    Default
    cfi.sampson@gmail.com
  44. #42
    Join Date
    Jan 2017
    Posts
    3
    Default
    Email sent
  45.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
