Hi, I've got some WR450 wheels (RAD Hubs) that I need to put a 220mm rotor on the rear wheel.
I'm trying to fit these wheels on my Beta XTrainer.
Does anyone know of a 220mm rotor that will bolt onto a Yamaha WR450 rear hub?
If anyone can confirm older Yamaha bikes use the same pattern but with 220mm rotor, that would be great. It's really hard to find solid info on the bolt circle diameter, but hub-centric mounting points and diameter aren't hard to find.
