05 crf450r
Results 1 to 5 of 5
Thread: 05 crf450r
  1. #1
    Join Date
    Sep 2015
    Posts
    2
    Default 05 crf450r
    My bike is a bitch to kick over and I just cleaned out the carb but it still struggles to kick start but if you bump start it, it will run fine. The carb was pretty nasty so I think I'm gonna buy the rebuild kit for it just so it's nice and fresh. I already need to replace one part and the kit is only 35$ anyway, plus I enjoy cleaning carbs anyway but any suggestions to help it start up easier. And the valves were recently adjusted before I got the bike so that shouldn't be the problem unless the people at the shop lied.
    Sent from my SM-J320R4 using Tapatalk
  2.
    Advertisement
  3. #2
    Join Date
    Apr 2015
    Location
    Gordon's Bay South Africa
    Posts
    56
    Default
    Definitely check the valve clearances as well.
    TM Racing....
  4. #3
    Join Date
    Oct 2014
    Posts
    2,005
    Default
    Yes, check the valves. When I sold my FZR to a friend I dropped it off at a local shop for "all" fluids changed, tune up, check/adjust valves and synchronize the carbs (as I just installed a jet kit in the carbs and someone sucked all the mercury out of my carb sticks). Needless to say, only the oil was changed, the valve cover was removed so I assumed the did check the valves and it had new plugs in it. They knew it was being sold and just let stuff slide. They didn't realize I rode with the guy and would see my old bike all the time. Voiced my concerns to the store manager and have never darkened their doorway again.
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Sep 2015
    Posts
    2
    Default
    Thanks. After I rebuild the carb I'll send it over to my shop that I go to because it seams like that probably happened
  7. #5
    Join Date
    Oct 2014
    Posts
    2,005
    Default
    Good call, cheap insurance. I do stuff for people selling trucks all the time, and they do have a tendency to be cheap. They'll want me to put one gear in it and they tell the buyer it was rebuilt. I have no problem throwing the seller under the bus and showing the new owner the work order, after all he pushed me in front of the bus by inferring it was rebuilt and had a warranty.
  8.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
