KTM 85 can I upgrade to a 36 spoke hub?
Results 1 to 8 of 8
Thread: KTM 85 can I upgrade to a 36 spoke hub?
    Sep 2016
    25
    Default KTM 85 can I upgrade to a 36 spoke hub?
    Been having a hard time finding a 17x2.5 32 spoke rim for my KTM 85. Does anyone know what hub with work with it that is a 36 spoke since they're easier to get rims for?
    I've tried searching but nothing useful came up.
    Thanks in advance!
    Sep 2016
    25
    Finally found what I needed.
    Aug 2008
    Jax, FL
    118
    Items for Sale
    What was the solution
    You will lose money chasing women, but will never lose women chasing money
    Sep 2016
    25
    Found these, but I decided to run 3.5x17 front and back because I found some 32 spoke ones for uber cheap.
    Aug 2008
    Jax, FL
    118
    Items for Sale
    I would lrefer to run 17s also, where did you source the rims? Also what brake setup eill you be running?
    Sep 2016
    25
    These are the wheels I'm running, called Buchanan's spokes and told them what I had and they sent me the correct spokes. Unfortunately I order the wrong diameter so had to drill out the holes a little bigger on the rim so it cost a little more with labor
  9. #7
    Aug 2008
    Jax, FL
    118
    Items for Sale
    Thanks for the info, are you upgrading brakes or staying stock. If upgrading, what all mods are you making?
  10. #8
    Sep 2016
    25
    Forgot about that, I have a 450 front caliper that I'd like to use with a 320mm disk but I'm having trouble trying to find the correct one because my hub is a 4 bolt vs the 6 bolt on the bigger bikes.
    I've found some that I think I can use but they show generic picture of the product so I can't be sure
  11.
