OK, so I am soon to be the proud owner of a SM 450R (ordered and paid, just waiting for delivery) and was curious about the break-in. I downloaded and read the owner's manual and it gives a brief summary of taking it easy but nothing concrete.
My last brand new bike was a CBR 929 and I recall having to keep it under 5k for the first while (and mixing the revs up in that range) and then keeping it under 10k (again not constant rpms)....all the while not going WOT or anything nasty for the first 1000km or so. Then once the 1000km oil/filter change and checkup, I was able to let it rip so to speak.
Is this how I should ride the Husky for the first bit? I have talked to a couple SMR owners and their break-ins varied so I was hoping I could get a little more input.
I took it kind of easy for the first 1000km, but after changing the oil & filter and checking the valves, (they were fine), I considered it ready for full-throttle. On the other hand, I have a lot of fun riding it without using full throttle or revving it to what I assume is near redline, and it's not very comfortable to ride for long on the freeway at speed, so I don't tend to abuse it.
Recommended mods: +1 front/-3 rear sprockets, Sil Motor exhaust, 450MX jet kit, (150 main, different needle and pilot jet), and a black anodized Renthal Fatbar w/Ferracci handlebar clamp to make it look that much cooler.
I'll summarize: Compression pressure pushes the rings out against the cyclinder wall. The rings wear in against the micro cross-hatch pattern on the cylinder wall and the cylinder wall wears in against the compression rings. It is okay to put your bike under a maximum load in the first few gears but do not bring the engine to redline.
yo Peter, so how do you set it to read RPM's I dont see any instructions on how to set it up that way.. :headscrat .. I dont think I have reached even 8k so I'm sure I'm okay.. It's just a bit scary when you down shift before the turn to try and back the rear for it may jump to the red rpm range but I think I'm okay.. just want to see in on the guage.
First of all you'll need to score a digital tach. Most of them have a memory that allows you to recall highest rpm. Daytona makes a good one that is backlit but its about $150. Very simple to install. There are cheaper ones available from Sendec but there is a delay in the LCD readout. The SMR has relatively close gear ratios so if you brake while downshifting, you shouldn't have to worry about over revving the motor. Another option is to get a slipper clutch or even a rekluse Z Start auto clutch. With the Z Start, it will take a little time to get used to and you might have to try different springs to change the stall speed to find what works best for you.
Oh man that is soo weak.. I thought the guage that came with the Husky had a tach setup.. Well that answers that. No wonder I didn't find instructions in the manual ehhy.. I like how the conventional clutch feels, seems to drift fine for now.. Awsome bike is all I could say.. even there is no tach.. :headshake
The tach is not a necessity. I hardly even look at mine anymore but it is still installed because I use the hour meter function to keep track of maintenance.
True true, just wanna see how much i'm turning the motor after a track session or something. Bro you should hit Hollister this Friday with your TE, I'm going with a few buds..
So it is YOUR bike I was drooling over last Saturday!! Mine is due in next weekend, but let me say your bike looks and sounds deadly, a real piece of work. Bill is the man when it comes to Husky's, so if we have a club we will have to use 5th gear as our headquarters.
Yeah, waiting really is the hardest part. I would have thought parting with the money was but I just keep thinking of how cool it would be once I get the bike. I already have some parts to throw on it that I got last month for my 31st birthday; Cycra Pro bends, Acerbis Cyclops headlight, etc.
It should be great though, as soon as it comes in I am throwing insurance on it and getting out there, the weather has been fantastic!
Definitely.. I hope to get it this week sometime!! Really the only parts I think im going to put on right away is gearing for the street and acerbis protectors.. oh.. and sliders of course. haha
Yeah? What gearing are you thinking of? I have not even ridden the bike yet but with a 6 speed I would think the stock gearing might be OK...what kind of top speed are you looking to get out of it?
Apparently the consensus is +1 in the front and -3 in the back for day to day riding.
I obviously dont plan on putting many highway miles on it, but at the same time dont really want to be running it wide open all the time.
Will have the stock setup on hand for the track through.
Related Threads
SuperMoto Junkie
1.8M posts
116.2K members
Since 2004
