Ok guys i just got a nice little package delivery from Dan at Motoxotica. :bowdown:Last week he told me cam chains were out a month on B/O, the UPS man just dropped one off at my house ten minutes ago...
So heres the start of it,
Paid 166 bucks for the following items listed by part number
800058541 --> Husky Cam Chain $95.95
38010019 --> Motion Pro Flywheel Puller (labeled YFM, 35mm X 1.5mm) R.H.$38.99 unless ya want the one from husky which is around $100
800063644 --> Waterpump Gasket$4.99
161503601 --> Valve cover Gasket x2 $2.99 ea
Ill be doing the work on the bike after i finish this damn summer school. Ill be posting necessary tools, procedure, any little tricks i find along the way and small details i would want my feller 610 riders to know... as well as my typical barrage of pictures for those who just dont want to read my babel.
I just tapped a screwdriver into the gasket to wedge the mating surfaces apart. It was well stuck together. I did crack my cover however near one of the bolt holes I don't know if I don't it taking it off or when I was refitting it. So just be careful.
I need a favor from you guys. I got this husky 510 used, the lower chane roller doesn't seem to be in the right place. Right now is held were the botom bolt is for the bike stand, seems a litle to low,the chain is rubbing the frame( crossmember). I cant fit a biger roller either cuz is to close to the crossmember
I looked the parts manual and the bolt is grayed out, no clue whe it goes.
A picture would be appreciated very much.
I'll take a pic of the rollers on my 610 for I when I get a chance. Maybe a pic of where it's rubbing might help people understand better what the problem is.
Thanks for the reply. So I figured that's the part is gone.
Now it's time to figure out to weld something back. Currently the engine is off for head work so I'll wait till that's done and have the chain installed.
Need to make something stronger than factory I gues but in the same time not to block that bolt for the swing arm.
The roller and roller mount is missing. Hard to figure it out from the picture I know cuz the chain is not on.
I'm going to take more picture and probably open a new thread.
Apreciate you trying to help
Can someone give me a count on number of links in a 610 chain?
I'm trying to buy chain off the roll here in central America.
Tried to count off the photo but it's blurry.
I like the idea of splitting the chain.
Feed it through the cap.
Just need to peen a link together.
I just bought my second 07 SM610, checked the CCT and it only had 2 clicks left on the rod :headshake Looks like I will be doing this hopefully in the next week or so.
I went ahead and called my local dealers and no one had the parts in stock, so I then called Hall's Cycles and turns out the had all the parts in stock. They were very knowledgeable, professional, and I would recommend them to anyone looking for parts.
I was able to get the parts for less than what the original post prices were plus $14.00 for shipping.
Cam chain $60.75
Water pump gasket $2.99
Valve cover gasket $0.99 each
Reed valve petal $5.25
Valve stop $5.99
Reed valve screws $0.99 each
Flywheel puller tool $29.50
They also gave me a little bit of a military discount on top of these prices so I was very satisfied. Parts were ordered and shipped 4/14/2016 and are scheduled to be at my doorstep 4/19/2016. Ill keep you guys updated! Cant wait to get the bike back on the road!
If anyone is looking, I've got a Timing chain, WP gasket, flywheel puller, and 3 Barnett clutch cables that I'd let go of for pretty cheap, sold my 610 last winter, don't need these parts.
All pics are reloaded onto the first post... thanks for the heads up hollywoodcrash
...Edit, damn photobucket had their watermark all over the place, right click each photo needed for detail and open in new tab and it will come clear as day. Happy cam chain quarantine day.
I just wanted to say thanks again for posting this thread. I bet there are loads more people who don’t post here but have used it for info!
