Heated grips for dirtbikes/tards
Results 1 to 29 of 29
Thread: Heated grips for dirtbikes/tards
  1. #1
    Join Date
    Feb 2006
    Location
    Pisgah Forest, NC
    Posts
    5,649
    Default Heated grips for dirtbikes/tards
    I just saw an ad for some heated grips for dirtbikes here or at Thumpertalk...or maybe it was in a catalog I threw out.
    But anyway they were just like these liners that fit under any grips you wanted and ran off your coil (if you don't have a battery) I suppose.
    Anyone know where to find them, searching led me nowhere.
  2.
    Advertisement
  3. #2
    Join Date
    Apr 2009
    Location
    Rocky Mount, NC
    Posts
    1,323
    Default
    Here are the ones I have seen used by guys on a KTM site, they say they are better than some of the others. Install and ziptie the wires to the throttle tube so they don't come loose, then install grips. Guys say you can safety wire over them, just don't go crazy enough with it to cut through the grip.
    http://www.dual-star.com/index2/Ride...d_grip_kit.htm
    I'll be getting some soon I think...
    Gerry
    09 KTM 250SXF/SMR
    08 KTM 450XCF/SMR
    08 Honduh 150R
    Bunch of 100s.
    McGinnis Custom Knives
  4. #3
    Join Date
    Feb 2006
    Location
    Pisgah Forest, NC
    Posts
    5,649
    Default
    Thanks Gerry. Not the ones I saw but close enough.
  5. Remove Advertisements
    SuperMotoJunkie.com
    Advertisements
  6. #4
    Join Date
    Mar 2006
    Location
    Denver, CO
    Posts
    79
    Default
    Dual Star can be hit or miss, do an ADVR search on it. The maker is symtec and can be found directly at Symtec-inc.com
    I called directly and got the elements for about $35 shipped with out the two position switch as I have them already or can get them cheaper locally.
    Be sure to insulate the left side from heat loss into the bar, they can be worthless if you don't do that.
  7. #5
    Join Date
    Nov 2007
    Location
    Used to live in Crestview FL, now ????
    Posts
    1,730
    Default
    +1 on the symtec. I've heard they are of better quality. I have a version similar to dual-star that I got from KTM hard parts. They have worked great for 2 years. I've had to replace a couple of switches and some heat sinks that give the elements "low" setting. All and all maybe $20 for replacement parts but the elements under the grips have not failed.
    Symtec's are supposed to have right and left specific elements to compensate for the thicker rubber on the left grip.
    ~Tim
    "04 625 SXC
    '04 625 SMC 76,xxx mi.
    '97 CR500 SOLD
  8. #6
    Join Date
    Feb 2006
    Location
    Pisgah Forest, NC
    Posts
    5,649
    Default
    The only ones I can get locally in time for the weekend ride is a set by Moose, I hope they're not as crappy as the YZ stator they're known for.
  9. #7
    Join Date
    Aug 2006
    Location
    Mi
    Posts
    338
    Default
    Goose- I have been running the Moose heated grip for three years and they work fine. The one issue with all heat tape type warmers is the throttle tube. The tube does not allow the bar to warm up as well as the left side. When I installed the kit I put electrical tape on the left side to help even the heating. Also, wrap clear package tape around both elements so you don't damage them when you want to do a grip change. Works like a champ!!!!!!!!!!
    supermoto freedom available @ www.misupermoto.com
    05 DRZ400sm with all the crap.
  10. #8
    Join Date
    Feb 2006
    Location
    Pisgah Forest, NC
    Posts
    5,649
    Default
    Quote Originally Posted by Z400smk5 View Post
    Thanks Z400smk5 and everyone else, got it wired up tonight and will try 'em out tomorrow.
  11. #9
    Join Date
    Apr 2009
    Location
    Rocky Mount, NC
    Posts
    1,323
    Default
    Goose, I ALMOST bought some Trackside ones today at Cyclegear... man I hope I don't regret not getting them! I got to thinking of the hassle of finidng power on the KTM and... well I didn't get them.
    Let us know how they work...
    09 KTM 250SXF/SMR
    08 KTM 450XCF/SMR
    08 Honduh 150R
    Bunch of 100s.
  12. #10
    Join Date
    Feb 2006
    Location
    Pisgah Forest, NC
    Posts
    5,649
    Default
    Quote Originally Posted by Gerry McGinnis View Post
    The last sub-60deg ride I did I was wishing for some. You still have time.
  13. #11
    Join Date
    Feb 2006
    Location
    Pisgah Forest, NC
    Posts
    5,649
    Default Some pics of the grips
    Wiring harness I put together
    Leads coming out from under the grips
    Homemade switch bracket
    All done
  14. #12
    Join Date
    May 2007
    Location
    Flat Rock,NC Western NC
    Posts
    3,241
    Default
    For a cabnet maker you wire pretty good!
    09 Kawasaki KLX 450R
    2006 DRZ 400 SM SOLD
    1998 RM 250 SOLD
    Suspension by:
    www.fastbikeindustries.com
  15. #13
    Join Date
    Feb 2006
    Location
    Pisgah Forest, NC
    Posts
    5,649
    Default
    Thanks Mux.
  16. #14
    Join Date
    Apr 2009
    Location
    Rocky Mount, NC
    Posts
    1,323
    Default
    So how well do they work? I'll be putting some on my bikes for sure in a few weeks if they work pretty good!
    Gerry
    09 KTM 250SXF/SMR
    08 KTM 450XCF/SMR
    08 Honduh 150R
    Bunch of 100s.
  17. #15
    Join Date
    Feb 2006
    Location
    Pisgah Forest, NC
    Posts
    5,649
    Default
    No running test yet, just static while in the shop. I was gonna take 'er out for a short one this evening but the battery was dead from all the testing with the motor off.
  18. #16
    Join Date
    Jul 2009
    Location
    San Antonio, Tx
    Posts
    450
    Default
    so whats the verdic?
    i originally found this to be stupid, but it just got soo cold down here in texas! i mean it was like 100degrees 2days ago and now it's 40degrees and rainning and i was like, yup i need some heated grips when i get my bike running cause im riding with motocross gloves with kevlar knuckles so im gonna have cold hands... so im waiting to find out how this works!
    1993 Cr500r
    educatio est omnium efficacissima forma rebellionis!
    levels of insaity:
    1 - talks to self 2 - argues with self 3 - loses argument with self 4 - is no longer speaking to self
  19. #17
    Join Date
    Feb 2006
    Location
    Pisgah Forest, NC
    Posts
    5,649
    Default
    Works very well but I should have done more to insulate the left side as I was warned. I put a few wraps of electrical tape on that side but it wasn't enough to equal the plastic of the throttle tube on the right side. So when I switched the grips on 'high' my right hand got too hot but on 'low' my left hand was too cold. I'm gonna redo the left side with insulated duct tape, then I'll be good running the system on low I believe.
  20. #18
    Join Date
    Nov 2007
    Location
    Posts
    1,730
    Default
    Quote Originally Posted by Goosedog View Post
    Occurs to me that insulating the left side may not be the issue. The rubber on the left grip is probably close to twice as thick. That is why Symtec's have right and left specific elements. My next .02˘
    Anyone out there with Symtec's that can say if their heat is even with them. I have a another brand that does the same as yours. Still some heat is better than none.
    ~Tim
    "04 625 SXC
    '97 CR500 SOLD
  21. #19
    Join Date
    May 2008
    Location
    western mass
    Posts
    2,199
    Default
    have HOT GRIPS on my 98 councourse still work fine,and will run of the headlight of a dirtbike. dennis kirk ?? the grips from cycle gear work great !! had them on my whifes bulle. my wrx will get a set for ice raceing !!! great stuff !
  22. #20
    Join Date
    Aug 2008
    Location
    Atlanta GA
    Posts
    615
    Default
    Has anyone tried Dual Star's suggestion of thick heat shrink tubing and a throttle grip on the clutch side? Seems to make sense. Just checking before I order some.
  23. #21
    Join Date
    Jul 2008
    Location
    Plymouth, New Hampshire
    Posts
    230
    Default
    I just installed these on my '07 450 using the power from the little side bulb and I was just wondering how long it took yours to warm up? I ran my bike with them on high for a couple minutes and it felt like they were warming up slowly so I was wondering if that's normal or if they should get warmer quicker?
    2007 Husqvarna SMR 450
  24. #22
    Join Date
    Sep 2010
    Location
    Marietta, GA
    Posts
    637
    Default electrical output
    Does the DRZ (or any of the other bikes for that matter) actually have the excess electrical output to run heated grips? Or will you be draining the battery while doing so?
  25. #23
    Join Date
    Sep 2007
    Location
    On the islands
    Posts
    289
    Default
    Quote Originally Posted by yetimcclin View Post
    Not sure about the DRZ but the 610 which the OP has (or any 610 for that matter…), has enough electrical power to run this and more simultaneously
  26. #24
    Join Date
    Jun 2010
    Location
    Oklahoma City
    Posts
    73
    Default
    I have them on my DRZ and I have not had any problems with running the battery down at all. Of course I have not ridden long distances in the cold, not fun for this skinny guy. The heated grips in combination with my neoprene gloves equals toasty fingers. They were on the bike when I bought it so I have no clue as to what brand they are but I love them. Get some...what is it going to hurt?
    '06 drz400sm
    There are enough rude people in this world I don't need to be one of them!!!
  27. #25
    Join Date
    Oct 2007
    Location
    South East Aussie Coast
    Posts
    425
    Default
    I used electrical tape on my left bar, first one I didn't do enough layers, and it still didn't heat up as quick as the right. Second time I doubled the layers so it was as thick as the throttle tube, and now they're pretty damn close when they heat up. The grip will still stretch enough to fit over the tape with grip glue acting as lube when it's still wet, lock wired for good measure, just don't do the wire too tight. You can now get the elements on eBay from China for like 6 bucks. I paid 50 for the dual star copies from Vince Strang Motorcycles here in Oz. I suppose you get what you pay for.
    2004 'Berg FS650E : Rebuilt with 05 crank for 628cc, genuine Berg slipper, Taffy's DVSK & decomp, Taffy's jet kit, SSB Lithium battery, Starlane quickshifter, 16mm Brembo radial master & 6 pot Beringer
  28. #26
    Join Date
    Feb 2008
    Location
    Tulsa, OK
    Posts
    1,659
    Default
    The DRZ SM has enough power to run the heated grips. I ran mine through a relay to keep from draining the battery if I forgot to turn them off with the bike.
    To help the insulation problem on the left grip in the past I used large diameter heat shrink around the handlebar. You have to glue it down or tape it down on the ends though otherwise it spins easy. You can pick up the larger shrink wrap for cheap from harbor freight.
    Here are two helpful articles on wiring a relay and installing heated grips:
    http://www.canyonchasers.net/shop/generic/relay.php
    http://www.canyonchasers.net/shop/ge...-grips-alt.php
    KTM 450 SMR
  29. #27
    Join Date
    Sep 2010
    Location
    Marietta, GA
    Posts
    637
    Default
    I knew about the relay...I'm running one with my SV1000's heated grips. I just wanted to make sure the DRZ would run 'em. Sounds like it will. SWEET! I know what I'm gettin' for Christmas!
  30. #28
    Join Date
    May 2008
    Location
    western mass
    Posts
    2,199
    Default
    Put them on a switched line,i use a headlight lead but that depends on your bike. That way you will never forgett to shut them off.They will kill your battery quick. Nice thing about the light is it had its own fuse and is big enough to handle the extra load.
    Also check to see if you have a power point in the harness that is switched,comes on when you turn the key.
  31. #29
    Join Date
    Sep 2010
    Location
    Marietta, GA
    Posts
    637
    Default
    I prefer to run a relay off the headlight and run a dedicated, fused line for the grips. That's what I did for my SV and that's what I'll be doing for my DRZ. Same advantage of not having to worry if you turned them off or not, but without having to run that much extra load on the headlight line.
  32.
    Advertisement
Posting Permissions
  • You may not post replies
  • You may not edit your posts
